penzfan
#1 Posted : Monday, February 27, 2017 9:23:59 AM(UTC)
penzfan
Broiler stopped working after we pressed the BROIL button on the key pad. BROIL and 550 displays on the digital readout for 25 seconds when the BROIL button is pressed then it turns off. Oven and Convection Oven all work fine I have replaced the $250 Control Panel and that did not fix the issue. I have just tested all the sensors, probe and thermostat and here are the results. Not sure what they should be reading as far as ohms.
Test results:
Broiler and Bake elements read 21.5 and 16.9 ohms
36TX22 Sensor showed no ohms reading
Temp Probe showed no ohms reading
36TX26 Sensor read 1.1 ohms
318003614 Thermostat read no ohms across the two outside connections and 1.2 ohms on the two connections that are next to one another
All components were disconnected/removed and tested
Pictures available
#2 Posted : Monday, February 27, 2017 7:24:20 PM(UTC)
Did you press the Start button after you pressed the Broil button?
penzfan
#3 Posted : Tuesday, February 28, 2017 11:26:40 AM(UTC)
penzfan
Did now. Broiler working.............duh
