My Samsung dryer does not heat and shows no error code. The dryer continues running even after pushing the power button to turn it off. It will stop running if you open the door but as soon as the door is shut it starts again with no display or lights whatsoever on the panel.
I have the same issue, what did you find wrong with yours?
Originally Posted by: jhself I have the same issue, what did you find wrong with yours? What did you end up doing to fix your dryer?
Originally Posted by: autoglassguy My Samsung dryer does not heat and shows no error code. The dryer continues running even after pushing the power button to turn it off. It will stop running if you open the door but as soon as the door is shut it starts again with no display or lights whatsoever on the panel. What did you end up doing to fix your dryer?
