HOTPOINT Top Freezer HTH17CBT2RWW...Hello: I recently moved and while I was driving on the highway (70 mph) with my Fridge in the truck, a gentleman pointed at my Fridge. I pulled over and discovered that the top freezer door was all the way open and I found white plastic remnants on the floor of the truck. The "after" transport problem is that the freezer door is opening all the way and hitting the side of the fridge. The refrigerator door is fine, since it was strapped closed and has a hinge at the bottom that was not affected. I am not able to tell from the diagrams what freezer door part hinges needs to be replaced. I snapped (3) pictures of the freezer hinges in different views. It is enclosed in an attachment. Thank you. Kindest Regards, Traci Traci in Training attached the following image(s):
