lynben
#1 Posted : Monday, March 31, 2014 6:17:43 PM(UTC)
lynben
dryer runs fine, drys clothes fine, but when clothes are dry will not shut off. (electric dryer)
fairbank56
#2 Posted : Monday, March 31, 2014 6:59:58 PM(UTC)
fairbank56
Does this only occur in auto dry or both auto dry and timed dry cycles?
Eric
lynben
#3 Posted : Tuesday, April 1, 2014 12:37:56 PM(UTC)
lynben
Eric, thanks for your reply. I put a few wet clothes directly out of the washer in the dryer. set dryer on 30 minutes. timer ran fine, clothes dried well, dryer shut off. so I would say everything fine with times dry. but not auto. thanks
fairbank56
#4 Posted : Tuesday, April 1, 2014 1:23:51 PM(UTC)
fairbank56
Does timer advance at all during auto dry cycle? If not, may just need to clean the moisture sensor rods. If timer does advance but won't shut dryer off, then timer is the likely suspect.
Eric
lynben
#5 Posted : Tuesday, April 1, 2014 1:54:06 PM(UTC)
lynben
Eric, no, when on auto cycle knob does not turn, but does turn down to o on timer mode.
fairbank56
#6 Posted : Wednesday, April 2, 2014 4:44:36 AM(UTC)
fairbank56
Clean the moisture sensing bars in the drum. If that is not the problem, you probably have a faulty dryness sensor board.
GE WE04X10102 Board W/buzzer - AppliancePartsPros.com
Eric
