patpeery@aol.com
#1 Posted : Thursday, November 22, 2012 10:01:07 AM(UTC)
patpeery@aol.com
The dryer heats up and works properly except the thing will not shut off, I have to manually turn the dial to get it to quit running.
Any thoughts? Timer?
thanks
#2 Posted : Friday, November 23, 2012 2:27:42 AM(UTC)
Parts for GE DDE5100SBLWW Dryer - AppliancePartsPros.com
If it will not advance in both timed dry and auto cycle types then odd are that the timer is toast.
Getting tech info on GE's is difficult as they like to keep all tech info a big secret.
On most units the timer motor gets power via different paths in timed and auto which is why you have to check both cycle types.
You could check the timer by doing a live test.
If the timer motor is getting power (120 volts) but not advancing, it is toast.
I do not recommend you do this unless you have electrical experience.
[COLOR="Red"]There is 240 volts at the timer and it is lethal!!![/COLOR]
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 10/23/2012 4:23:08 PM(UTC)
Dryer will not shut off in automatic cycle (Dryer Repair)
by jennarnott 6/21/2012 12:02:09 PM(UTC)
Dryer will not Shut off (Dryer Repair)
by Jeremybrutonsupply 5/25/2012 6:00:53 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Maytag Dryer Will Not Shut Off (Dryer Repair)
by MJScott 3/20/2012 11:35:17 AM(UTC)
Maytag Dryer Will Not Shut Off (Refrigerator & Freezer Repair)
by MJScott 3/20/2012 11:27:36 AM(UTC)
kenmore dryer will not shut off and will start when the timer is on zero (Dryer Repair)
by brettb 12/13/2011 4:05:19 PM(UTC)
LDG8414AAE Maytag Dryer will not shut off (Dryer Repair)
by skora 11/3/2011 11:42:33 AM(UTC)
by GWG 12/30/2010 7:53:55 AM(UTC)
Dryer will not shut off but heats ok (Dryer Repair)
by twilliams0204 12/16/2010 6:26:06 PM(UTC)
by fixit33 10/4/2010 4:08:20 AM(UTC)
Dryer will not shut off. (Dryer Repair)
by jmkitson 8/5/2010 11:23:31 AM(UTC)
Amana Dryer will not shut off (Dryer Repair)
by kruczeric 6/8/2010 5:04:16 PM(UTC)
