I have a kenmore model 106.56673500 side by side fridge and having a problem keeping fridge side cold. Freezer is constantly 0f but fridge side runs from 40-55. I have been reading through all the helpful threads and have tried almost all suggestions. Air damper is open, light frost on coils, evap fan blowing cold air, return grill through center is clear of ice, damper is clear of ice. I have defrosted fridge for 24h then restarted and after another 24 h fridge is down to 35f. After adding 2 bottles of pop and a container of butter fridge temp rose to 46f and in 3 hours has only dropped 1 degree. Any other ideas? Also through my ultra crisp zone in the side of the fridge and the the hole in the crisper I am getting no airflow at all. Any other way to check if this is clear? Thanks
