The tub can be moved by hand and doesn't appear to be connected to the shaft. I found a ring in three pieces under the washer plate in the metal tub. I believe I need a new tub nut, but I don't see that on any of the exploded diagrams of the parts. Please help
See if this is the part you need Part number: AP3081384
but it may be that you need who leveling kit, hopefully not.
Ok got the nut off that holds the universal joint on and that was chore in and of it's self. I had to cut it off. Now how do I get the universal joint off. It looks to me like I am going to need a gear puller. Any suggestions?
