andbat
#1 Posted : Sunday, December 18, 2011 7:01:19 AM(UTC)
andbat
Views messages in topic : 3
The tub can be moved by hand and doesn't appear to be connected to the shaft. I found a ring in three pieces under the washer plate in the metal tub. I believe I need a new tub nut, but I don't see that on any of the exploded diagrams of the parts. Please help
sidfink43
#2 Posted : Monday, December 19, 2011 3:57:16 PM(UTC)
sidfink43
See if this is the part you need
Part number: AP3081384
but it may be that you need who leveling kit, hopefully not.
andbat
#3 Posted : Tuesday, December 20, 2011 6:16:47 PM(UTC)
andbat
Ok got the nut off that holds the universal joint on and that was chore in and of it's self. I had to cut it off. Now how do I get the universal joint off. It looks to me like I am going to need a gear puller. Any suggestions?
sidfink43
#4 Posted : Wednesday, December 21, 2011 5:22:25 AM(UTC)
sidfink43
It should just lift out, but putting things back together requires you to follow the instructions in the service manual. Here it is
http://appliancejunk.com...wnloads;sa=view;down=116
from AJ's site.
