jackw
#1 Posted : Thursday, October 6, 2011 1:16:34 PM(UTC)
jackw
I have a howling noise coming from by bottom mount Monogram refrigerator. I orginally thought it was the evaporator fan but the howling continued after it was replace. I discovered another part called the evaporator heater kit. Apparently there is a fan in the part and blow air over the drain pan. Like all Monogram parts this one is expensive - $700. I have seen repair comments on the newer Monogram models that indicate the drain pan fan is not really needed and can be unplugged. It only necessary in extreme conditions.
Two questions - Is this part necessary or can the fan be disabled and if so how do you get to the power cord. If it must be replaced how to you remove it. It looks very complicated. It appears that a refrigerant line must be removed to take out the unit.
Any help would be appreciated.
richappy
#2 Posted : Thursday, October 6, 2011 3:04:17 PM(UTC)
richappy
Yes, I see the part under the refrigerator. It's a heater and fan assembly to evaporate the water in the thin drip tray. Unless you have high humidity and store a lot of open containers in the fridg. you can disconnect it. Looks like the regular condensing fan just cools the compressor and no air from this reaches the drip tray. Thus, the worst that can happen is the drip tray will overflow. Might want to see if an air passage can be cut in to allow air flow to this.
I would tip the fridg back and try to locate the wires going to it. It might be helpful if you can locate the service sheet, usually behind the control panel, might have wiring info.
jackw
#3 Posted : Thursday, October 6, 2011 3:11:43 PM(UTC)
jackw
Thanks! The only problem I have now is to locate the connection. The refer is built in to the wall so finding the correct wires could be a problem. Unfortunately, according to the wiring schematic it looks like it is on the same circuit as the evaporator fan. So I can't disconnect it at the top next to the compressor. I am going to have to find a way to get to it from the bottom. Besides pulling the refer out of the wall any suggestions?
richappy
#4 Posted : Thursday, October 6, 2011 3:27:32 PM(UTC)
richappy
See my revised post above.
If you can get at the fan blade, you could always remove it. Also, the cause of noise just might be dust and dirt stuck in the airflow parts, sometimes you can take compressed air and blow it out.
jackw
#5 Posted : Thursday, October 6, 2011 3:45:45 PM(UTC)
jackw
It is very tight where the fan is located. No room and little visibilit even with the drain pan removed. And, unfortunately the wires come in from the back. I will either pull the refer out or disconnect it at the splice for the evap fan. Either case, you answered by bigger concern whether I could disable or had to replace the part.
richappy
#6 Posted : Friday, October 7, 2011 1:44:23 AM(UTC)
richappy
I just noticed, your condensing coils are under the drip tray, the heat from these should evaporate the water.
jackw
#7 Posted : Friday, October 7, 2011 11:22:46 AM(UTC)
jackw
For anyone with a noisy drain pan fan on a Monogram BM refer circa 2000 here is how to fix it. Remove kickplate. The fan is located on the left and is hidden behind a metal plate. You cannot see the fan nor the electrical connections. At the top of the metal plate is a single screw that attaches the plate to the bottom of the refer (bottom of freezer section). Remove the screw (you will need an extremely short screw drive) and the plate comes off. If the copper water line is in the way you may have to undo the copper water line and move it aside. With plate removed you will see the fan next to the water valve for the ice maker. Undo the electrical connection to the fan. You are done with a noisy fan unless you want to replace it. However, it is not necessary to replace the fan unless you live in a very humid area. As noted in this thread, the drain pan is heated and a fan is not normally required.:) Note that a replacement is very expensive - $450-700.
jackw
#8 Posted : Friday, October 7, 2011 11:27:04 AM(UTC)
jackw
BTW - this thread relates to model ZIC36NAB
Guest (6)
