I look in the bottom vent of the freezer where the evaporator coil is,it's clear.The problem that I see is the back wall to the top and bottom of the freezer was frozen.I defrost the ice by turning the temperature off.When I defrosted the freezer and turn it back on,it froze again.
With the freezer coils frozen, find the defrost timer behind the control panel and turn it till the compressor stops, then check for defrost action, if none, you either have a bad defrost heater, or defrost thermostat.
I turn the thermastat down to defrost.I can hear the ice melting.I can not see the ice because it inside of the back wall of the freezer.The ice is probly big inside the vent wall of the freezer?
You need a new defrost timer, call this parts site for part #, your model number will not work.
Originally Posted by: richappy You need a new defrost timer, call this parts site for part #, your model number will not work. The link I sent you of the defrost timer,where is it located in the freezer section.
Usually behind the control panel in the fridg section.
Originally Posted by: richappy Usually behind the control panel in the fridg section. The defrost control panel is working,The refridg is still not cooling.The therma control is working for the freezer.No, air is blowing in the refridg department at all.
