2 Pages<12
Tomsav31
#11 Posted : Sunday, May 22, 2011 4:02:15 PM(UTC)
Tomsav31
I look in the bottom vent of the freezer where the evaporator coil is,it's clear.The problem that I see is the back wall to the top and bottom of the freezer was frozen.I defrost the ice by turning the temperature off.When I defrosted the freezer and turn it back on,it froze again.
richappy
#12 Posted : Monday, May 23, 2011 1:38:44 AM(UTC)
richappy
With the freezer coils frozen, find the defrost timer behind the control panel and turn it till the compressor stops, then check for defrost action, if none, you either have a bad defrost heater, or defrost thermostat.
Tomsav31
#13 Posted : Tuesday, May 24, 2011 4:42:49 PM(UTC)
Tomsav31
I turn the thermastat down to defrost.I can hear the ice melting.I can not see the ice because it inside of the back wall of the freezer.The ice is probly big inside the vent wall of the freezer?
richappy
#14 Posted : Wednesday, May 25, 2011 12:50:18 AM(UTC)
richappy
You need a new defrost timer, call this parts site for part #, your model number will not work.
Tomsav31
#15 Posted : Wednesday, May 25, 2011 7:15:51 AM(UTC)
Tomsav31
The link I sent you of the defrost timer,where is it located in the freezer section.
richappy
#16 Posted : Wednesday, May 25, 2011 7:22:21 AM(UTC)
richappy
Usually behind the control panel in the fridg section.
Tomsav31
#17 Posted : Wednesday, June 15, 2011 9:41:12 AM(UTC)
Tomsav31
The defrost control panel is working,The refridg is still not cooling.The therma control is working for the freezer.No, air is blowing in the refridg department at all.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 6/18/2022 7:38:51 AM(UTC)
Just bought new side by side refrigerator but doesn't get cold enough (Refrigerator & Freezer Repair)
by Hotlynx16 3/28/2022 2:47:44 PM(UTC)
Admiral side by side refrigerator external drip drain tray (Appliance Parts)
by Paul Bridges 1/14/2021 10:28:34 AM(UTC)
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
GE Profile Side by Side Refrigerator Model ESS25XGMB (2001) not cooling (Refrigerator & Freezer Repair)
by boxer 7/14/2019 7:19:21 PM(UTC)
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 2/21/2019 7:14:22 PM(UTC)
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 6/28/2018 8:18:44 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
Side by side refrigerator keeps turning on and off (Refrigerator & Freezer Repair)
by Rasenganguy 9/27/2016 6:43:34 PM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9/17/2015 11:52:33 AM(UTC)
Side by side refrigerator not cooling. (Refrigerator & Freezer Repair)
by Jms55 1/26/2015 12:24:12 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
2 Pages<12
