Glen Barclay
#1 Posted : Saturday, October 18, 2008 9:35:47 AM(UTC)
Glen Barclay
I need to replace the lid switch on my series 90 washer. The consol has two screws in the front (at an angle). I had removed these but still cannot figure out how to get the consol off and get the top of the machine off to access the switch.
libertyappl
#2 Posted : Saturday, October 18, 2008 11:22:19 AM(UTC)
libertyappl
There should be 2 clips, one on each side about 2 inches from the corners. You can use a putty knife to release these and raise the lid.
Nat
Drags1998
#3 Posted : Saturday, October 18, 2008 12:36:26 PM(UTC)
Drags1998
Remove the screws, pull console foward 1/2" and rotate over backwards, remove the 3 wire connector to the lid switch, remove the 2 GOLD colored clips, Tilt cabinet foward and slide off the washer.:)
Glen Barclay
#4 Posted : Sunday, October 19, 2008 4:03:09 PM(UTC)
Glen Barclay
thanks for the information
Glen Barclay
#5 Posted : Sunday, October 19, 2008 4:04:36 PM(UTC)
Glen Barclay
There does not appear to be any clips there. As I look at it there are plastic somethings at each corner.
#6 Posted : Monday, October 20, 2008 10:38:19 AM(UTC)
Hi Glen,
These clips are #6 on the break down diagram. Insert a flat screwdriver into the front edge of the clip and pry back.
- The part number for the lid switch is AP3094500
Glen Barclay
#7 Posted : Wednesday, October 22, 2008 9:06:20 AM(UTC)
Glen Barclay
Thanks for the great information. I am now in the final stages of putting the machine back together. I really appreciate all of the great info all of you have given me...
#8 Posted : Wednesday, October 22, 2008 11:53:30 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
Kenmore Series 90 Washer Agitates Clockwise (Washer Repair)
by tomgf 10/30/2017 8:02:16 PM(UTC)
Kenmore series 90 washer spins while draining (Washer Repair)
by Tbone4444 11/13/2014 11:03:16 AM(UTC)
Kenmore series 90 washer won't spin in Perm Press cycle (Washer Repair)
by ozbirn 2/8/2013 3:56:30 PM(UTC)
Kenmore Series 90 Washer Not Draining but Does Spin (Washer Repair)
by TaquacheDawg 3/28/2012 9:26:19 PM(UTC)
Kenmore Series 90 Washer - spin problems (Washer Repair)
by dgb20 10/11/2011 4:10:07 PM(UTC)
Kenmore series 90 washer Control Knob (Washer Repair)
by chiefjack 4/15/2011 7:19:53 AM(UTC)
Kenmore Series 90 washer (Washer Repair)
by dguern1 7/10/2009 4:13:36 PM(UTC)
