digital display not working. Oven lights work. electric double oven. Can someone help me diagnose and fix display?
Does the ovens heat? If not the your probably need a new control board (aka microcumputer part number AP3767567) You may want to check the connections to the touch pad and control board first. Nat
I can't get the oven to work. I hear beeps when I touch panel.
After using Auto oven Clean, door will not open. Stays in locked position
Try killing the power to it and letting it sit for a minute the kick it back on Sometimes the door lock motor will run again to unlock it
