westydog
#1 Posted : Wednesday, January 19, 2011 10:25:01 AM(UTC)
westydog
How is the membrane removed? Appears front panel has to be removed first, but even after removing one screw at the top of panel it will not budge. There must be a secret.:)
westydog
#2 Posted : Wednesday, January 19, 2011 4:08:58 PM(UTC)
westydog
Well, I found the trick - I removed the small plastic screen over the panel after removing the top vent cover and just behind the small fan is a tab that has to be raised up and the panel tilts forward. The rest is easy but care must be practiced when removing the old membrane as the adhesive is strong.:)
