Mikedaddy2
#1 Posted : Sunday, November 14, 2010 12:42:43 PM(UTC)
Mikedaddy2
My refrigerator and freezer neith one cool. The blower works, but blows just air. I looked at changing out the control damper, part #240521103, Is this what I need to fix or am I looking in the wrong place?
kayakcrzy
#2 Posted : Sunday, November 14, 2010 2:00:14 PM(UTC)
kayakcrzy
If there is no cooling, you are most likely looking at a compressor issue. I would replace the overload and relay kit on the compressor. Tom ApplianceEducator.com
#3 Posted : Monday, November 15, 2010 1:45:45 AM(UTC)
I cannot find any info on your given model number, please check it.
As kayakcrzy said the damper will not be the problem.
It just regulates the amount of cold air entering the fresh food side of the unit.
Since the freezer is not cold you simply do not have any cold air.
First you have to determine if the compressor is running.
You can usually hear it, also you should be able to feel it vibrating and it should be warm.
If it is not running it could be the start device (kayakcrzy) or the freezer thermostat (control) or the compressor itself.
If it is running then it may be a defrost problem, the freezer would be cold just not cold enough. If not a defrost problem then it will be a problem in the sealed system.
Here are a couple good links on basic fridge repair.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
Frigidaire side by side door fridge- timer question (Refrigerator & Freezer Repair)
by Chickadee 10/3/2016 5:00:58 PM(UTC)
Frigidaire Side By Side Compressor Will Not Start (Refrigerator & Freezer Repair)
by stockler707 7/17/2015 5:56:31 AM(UTC)
Frigidaire side by side, freezer temp erratic, fresh is ok (Refrigerator & Freezer Repair)
by nigelquest 12/27/2014 10:47:11 AM(UTC)
Frigidaire Side by Side not cooling (Refrigerator & Freezer Repair)
by mrmagic 12/2/2014 10:13:52 AM(UTC)
Frigidaire Side By Side not cooling to set temp (Refrigerator & Freezer Repair)
by Jedi.Cowboy 11/26/2014 6:48:31 AM(UTC)
Frigidaire side by side won't defrost (Refrigerator & Freezer Repair)
by scmiller 11/13/2014 9:06:57 AM(UTC)
Frigidaire side by side not cooling may be defrost problem (Refrigerator & Freezer Repair)
by ScotB48116 8/5/2014 9:29:43 AM(UTC)
Frigidaire side by side ice maker/freezer issues (Refrigerator & Freezer Repair)
by franchz 7/16/2014 6:20:00 PM(UTC)
Frigidaire side by side not cooling properly (Refrigerator & Freezer Repair)
by RodH508 7/6/2014 10:48:38 AM(UTC)
Frigidaire Side by side fridge not cooling properly (Refrigerator & Freezer Repair)
by Lebbrin 1/1/2014 1:24:48 PM(UTC)
Frigidaire side by side refrigerator not cooling (Refrigerator & Freezer Repair)
by ducatiduke 12/22/2013 8:42:21 PM(UTC)
Frigidaire Side by Side Running 24/7 (Refrigerator & Freezer Repair)
by jhknight 9/8/2013 7:37:01 PM(UTC)
Frigidaire side by side Freezer not Freezing (Oven Repair (including Ranges and Cooktops))
by ac132675 7/25/2013 10:24:45 AM(UTC)
