14 Pages«<34567>»
#41 Posted : Wednesday, July 21, 2010 6:26:34 PM(UTC)
Originally Posted by: homebrewdon Go to Quoted Post
I have a GE TBFM17VC refrigerator that I inherited and am having issues with. The freezer will cool down to 2.0 deg F on coldest setting, but the fridge maintains the same temp of 50deg despite cooling setting. Nothing is in the fridge except some beer, and there is no ice on the back panel in the freezer, also the freezer fan is blowing strong. I can not detect any fan movement in the fridge. Whats my next step? Thanks.
Don
Don,
Make sure the freezer temperature control is set on "A" or "B". Wait about 24 hours to see the difference and post the result.
Here are the breakdown diagrams and Replacement parts for General Electric TBFM17VCBL Refrigerator | AppliancePartsPros.com
bunji69
#42 Posted : Tuesday, August 17, 2010 8:51:40 PM(UTC)
bunji69
Refridgerator not getting cold, but Freezer working fine. Help GeneCoils were iced over. MAybe defrost not working?? how do I troubleshoot this on my Maytag MSD2758GE..
krw_cox
#43 Posted : Wednesday, August 18, 2010 8:55:02 AM(UTC)
krw_cox
GE TFX26ZPDA side by side
I found the fridge wasn't getting below 65 but freezer is working. After reading the thread I noticed the back panel of the freezer hasn't defrosted in a while. I've unplugged the fridge and removed the inside panel of the freezer to see tons of frost. I removed the heating element & it measures 1M ohms which I'm guessing should be closer to zero ohms. Is that correct & how do I know if I need to replace the thermostat also?
Hoping to get some help troubleshooting.
Thanks,
Kevin
#44 Posted : Wednesday, August 18, 2010 12:50:09 PM(UTC)
Originally Posted by: bunji69 Go to Quoted Post
...Coils were iced over...
Sounds like there is a faulty defrost system. Very common problem with Maytag refrigerators and the solution, most likely, is to replace the adaptive defrost control (#13 on the diagram). You also have to defrost the evaporator coils manually. A hair dryer may help.
- The adaptive defrost control Part number: AP4070403
#45 Posted : Wednesday, August 18, 2010 12:55:12 PM(UTC)
Kevin,
The defrost heater is bad. No doubt about it. It comes with the new defrost thermostat, so you do not have to worry about it.
- The defrost heater assembly Part number: AP2071521
krw_cox
#46 Posted : Wednesday, August 18, 2010 6:55:18 PM(UTC)
krw_cox
Thanks Gene. I had only seen the heater sold by itself. And thanks for providing the part link.
Kevin
#47 Posted : Wednesday, August 18, 2010 7:08:49 PM(UTC)
You are welcome Kevin. Keep us posted.
stevenycc
#48 Posted : Tuesday, September 21, 2010 2:23:25 PM(UTC)
stevenycc
Hi,
My refrigerator is Whirlpool ED25RFXFW01. The refrigerator is not cold enough on Sat, but the freezer is working. On Monday morning, the freezer is not working and the ice cream is melting. Funny thing is the freezer is working again after I came back from work on Monday evening.
Can you tell me where to check and which parts that I need to replace?
If you have the picture link that will be greatful.
Thanks,
Steven
#49 Posted : Wednesday, September 22, 2010 6:27:15 PM(UTC)
Originally Posted by: stevenycc Go to Quoted Post
Hi,
Thanks,
Steven
Steven,
The first thing I would do is remove the rear cover and clean the condenser. Make sure the fan next to the compressor is working.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED25RFXFW01 | AppliancePartsPros.com
stevenycc
#50 Posted : Thursday, September 23, 2010 7:19:44 AM(UTC)
stevenycc
Steven,
Hi Gene,
Thanks for reply. I clean the condenser and it is working. It looks like the defrost probelm, b/c the coil is iced. Does my model has the defrost control? How to check whether defrost heater problem, defroster timer problem, or defrost thermostat problem?
Thanks,
Steven
Guest (10)
GE GBS22HCPAWW - Refrigerator not cooling, but freezer is working (Refrigerator & Freezer Repair)
by drl213 10/16/2009 6:34:42 AM(UTC)
by cdnhawk02 9/14/2009 2:22:31 AM(UTC)
14 Pages«<34567>»
