gmhandel
#1 Posted : Saturday, September 18, 2010 4:57:34 PM(UTC)
gmhandel
My Maytag front end loader stopped midcycle with water not completely drained and has been frozen and locked shut. I tried everything the manual said. Held On/Off button for over 2 minutes. Did not unlock. I even unplugged it for an entire day and it still wont unlock. Held wash selection dial for over 2 minutes. Did not unlock. Display has error OE which is not in the manual. I can't get in touch with Maytag help line because they are closed until Monday. My clothes have been sitting in the washer for 2 days now. Can some one offer help?
brockner75
#2 Posted : Sunday, September 19, 2010 5:50:45 PM(UTC)
brockner75
gmhandle-
I have the exact same machine and have a lot of manuals. I do not know how the attatch these manuals but if you want to check out "wiring harness?" in the forum The links are on there. They were very helpful.
the error code OE is describe as this. A fault is detected in the water level sensor. Data (frequency) shows the water level is at or above the overflow level. In the manual it says to check to make sure the water valve is not stuck. If water valve is ok check water level sensor.
As far as the door lock goes, my machine did the same thing and I took the top off and unplugged the relay for the door lock sensor. (It is a tight spot.) Make sure the machine is unplugged. Then plug the relay back in and give that a try. I hope this is helpful.
Brockner75
FIRSTSHIRT
#3 Posted : Monday, September 20, 2010 11:19:34 AM(UTC)
FIRSTSHIRT
Ur problem sounds similar to mine awhile back. Check out the 'wax motor' possibilities. Again, may not have any connection to ur trouble but wax motor does affect locking door. U can search maytag neptune repair kit and it will talk about replacement. it is quite easy
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Maytag Neptune front load washer MAH7000AWW (Washer Repair)
by kerrlakecrappieman@gmail.com 3/16/2019 7:53:32 PM(UTC)
Maytag Neptune Front Load Washer Squealing (Washer Repair)
by ArcadeMan 2/10/2014 10:31:10 AM(UTC)
by debbierocks 4/1/2012 6:59:03 AM(UTC)
maytag neptune front load washer (Washer Repair)
by lbrennan 3/12/2012 12:36:33 PM(UTC)
by barbara witkowski 5/18/2011 4:56:21 PM(UTC)
Need Help with a Maytag Neptune front load washer....stops running at each cycle. (Washer Repair)
by carebear03303 2/11/2011 6:43:15 AM(UTC)
Maytag Neptune Front load washer (Washer Repair)
by mnunno 2/26/2010 1:15:35 PM(UTC)
MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet (Washer Repair)
by debbielf 8/31/2009 8:05:14 AM(UTC)
Maytag Neptune Front Load Washer Help (Washer Repair)
by debster101 7/23/2009 1:03:06 PM(UTC)
Maytag Neptune front load Washer (Dryer Repair)
by castillocm 7/31/2008 4:03:24 PM(UTC)
