Marine Gunny
#1 Posted : Monday, August 23, 2010 5:22:28 PM(UTC)
Marine Gunny
My wife was recently doing laundry and in between loads the dryer stopped working. Being an electronics technician in the military I started with the most logical players.
I checked out the door switch and the push to start switch with an ohmmeter (both good). I shorted out the wires going to the thermal switch and it still didn't turn on.
We are a military family on a tight budget. Any suggestions on how I can fix this thing myself would be greatly appreciated.
#2 Posted : Tuesday, August 24, 2010 8:15:55 AM(UTC)
Here is a parts breakdown. Closest I could find is TQ0
Replacement parts for WHIRLPOOL RED4400TQ0 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram for the VQ0
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If power is OK.
Unplug the unit, set the timer to mid scale timed dry and check the BU/BK timer contacts.
Be sure to disconnect at least one side so that you do not read an alternate/parallel circuit path.
If OK
Check the motor windings for continuity.
Marine Gunny
#3 Posted : Wednesday, August 25, 2010 9:05:55 AM(UTC)
Marine Gunny
denman - I cannot thank you enough. I had checked the breaker at the plug and assumed that since I was getting the 120V I'd be getting the 240V. I had also checked the breaker and since it wasn't tripped I had ruled it out. One side was working, the other side was not. I figured that it still would have tripped the breaker.
After a quick run to Menards and $8 later my dryer works again!
Thanks again, much appreciated!
#4 Posted : Thursday, August 26, 2010 5:19:44 AM(UTC)
You are welcome
Military Man on a Budget Need Help with Roper (Dryer Repair)
by Marine Gunny 8/23/2010 5:20:29 PM(UTC)
