Janine
#1 Posted : Saturday, May 1, 2010 4:11:11 AM(UTC)
Janine
How do I repair my hotpoint wmd960 ultima washing machine with fault code F05? :confused: Also what does this fault cose mean is wrong with my machine?
sidfink43
#2 Posted : Monday, May 3, 2010 6:15:49 AM(UTC)
sidfink43
Your model number is not correct or complete, but in general you should find tech notes that explain the error code under the top or inside the lower service panel.
GE does not provide access to its technical data, so I can only refer you to the tech notes. If you need more help please post the full model number and what you have learned from the tech notes and we may have some more suggestions.
Janine
#3 Posted : Tuesday, May 4, 2010 6:52:07 AM(UTC)
Janine
Thanks for ur reply, ive worked out wot was wrong and sorted it out. The pump had a hair clip stuck in it....its now been removed and my machine is workin again!
sidfink43
#4 Posted : Tuesday, May 4, 2010 4:14:46 PM(UTC)
sidfink43
Very good!! Thanks for getting back to us and letting us know what was wrong.
