cmarble1
#1 Posted : Friday, April 23, 2010 3:54:18 PM(UTC)
cmarble1
In need of some HELP! Had a code f2 and Sud. Ran a
DIAGNOSTIC TEST all cycles checked out.
• Ran the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should have cleared the unit of the excess detergent.
• Checked the drain hose and make sure it is not plugged or kinked
• Checked Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Checked/ Cleaned Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Still had codes!
I replaced the pressure switch, code still showed.
I replaced the drain pump, code still showed.
I took off Pressure Tube Connector from tub and checked o-ring and to see if it needed cleaning. Reinstalled, code still there.
I took off the Eco Valve and cleaned. Reinstalled, code still there.
All connection were tested and checked to see if there was a break.
The MOTOR CONTROL UNIT was replaced 6 months ago.
Need some input Please!!! Is there a way to test the
CENTRAL CONTROL UNIT ???
