mnunno
#1 Posted : Friday, February 26, 2010 1:15:35 PM(UTC)
mnunno
Sounds like the main drum bearing is wearing out. Lots of noise on the spin cycle. Any help on how to remove and replace. Model MAH4000AWW
#2 Posted : Friday, February 26, 2010 3:48:52 PM(UTC)
Maytag does not sell this bearing separate. It comes as a part of the rear outer tub and price for this part went up to $535 + shipping for an over sized item. It makes such repair worthless.
On the other side, if you are handy enough, you can replace just the bearing. You can find some useful information in one of our previous threads: http://forum.appliancepartspros...ng-neptune-bearings.html
Here are the breakdown diagrams and Replacement parts for MAYTAG MAH4000AWW Washer - Horizontal Axis | AppliancePartsPros.com
mnunno
#3 Posted : Saturday, February 27, 2010 5:27:32 PM(UTC)
mnunno
Once again Gene you are the man. thanks. Mike
#4 Posted : Saturday, February 27, 2010 6:08:11 PM(UTC)
You are welcome Mike. Good luck and keep us posted.
mnunno
#5 Posted : Wednesday, March 3, 2010 2:19:44 PM(UTC)
mnunno
What exactly is the wax motor? and should I plan on replacing it while I am doing the bearing job.
#6 Posted : Wednesday, March 3, 2010 7:22:02 PM(UTC)
The wax motor is a part of the door latch and it has nothing to do with the bearing problem unless there is more problems with your washer.
dvaut
#7 Posted : Thursday, March 18, 2010 6:16:21 PM(UTC)
dvaut
I replaced my bearings after a lot of intensive web investigation. There is one important item that nobody talks about, that is, properly seating the drum. So I put up a web page on it at
neptune bearings
hope this helps somebody because if those bearings are not seated water gets in and all is in vain.
#8 Posted : Friday, March 19, 2010 12:53:51 PM(UTC)
neptune bearings
Just wanted to thank you for sharing your repair with us. Your post was very helpful and instructive.
Good luck with your washer.
bob mason
#9 Posted : Wednesday, May 9, 2012 2:40:57 PM(UTC)
bob mason
i need to know how to raise top lid. to i lift from the or rear. do i have to remove any parts first. thank-you. bob mason
Guest (6)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Maytag Neptune front load washer MAH7000AWW (Washer Repair)
by kerrlakecrappieman@gmail.com 3/16/2019 7:53:32 PM(UTC)
Maytag Neptune Front Load Washer Squealing (Washer Repair)
by ArcadeMan 2/10/2014 10:31:10 AM(UTC)
by debbierocks 4/1/2012 6:59:03 AM(UTC)
maytag neptune front load washer (Washer Repair)
by lbrennan 3/12/2012 12:36:33 PM(UTC)
by barbara witkowski 5/18/2011 4:56:21 PM(UTC)
Need Help with a Maytag Neptune front load washer....stops running at each cycle. (Washer Repair)
by carebear03303 2/11/2011 6:43:15 AM(UTC)
by gmhandel 9/18/2010 4:57:34 PM(UTC)
MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet (Washer Repair)
by debbielf 8/31/2009 8:05:14 AM(UTC)
Maytag Neptune Front Load Washer Help (Washer Repair)
by debster101 7/23/2009 1:03:06 PM(UTC)
Maytag Neptune front load Washer (Dryer Repair)
by castillocm 7/31/2008 4:03:24 PM(UTC)
