I'm having problems with the console when pressing the touch pad selection. Some buttons on the console work and some don't. The buttons that are most problematic are the "BAKE" selection and the "3" when trying to select the 350 tempreature. My question is which component could most likely be causing this problem, the micro computer located under the console, or the touch pad console itself?
Your help is very much appreciated!
this is a gas stove and electric oven. the console is really to control the oven. Start turns it on, but OFF doesn't turn it off any more. The timer off still works. Any ideas? How do we fix this?
The console seems to be sealed, so I don't know whether any thing leaked underneath it...
It's the KGRI801 KGRA806 series
